guidelines for determining the probability of ignition a released flammable mass
Guidelines for Determining the Probability of Ignition of a Released Flammable Mass
نوع فایل:  PDF
نوع زبان: انگلیسی
تعداد صفحات: 262
.pdf   Guidelines for Determining the Probability of Ignition of a Released Flammable Mass.pdf (اندازه 11.43 MB / تعداد دانلود: 955)
Author(s): CCPS
Publisher: Wiley-AIChE, Year: 2014
ISBN: 1118230531,9781118230534
Description
Complemented by an estimating tool spreadsheet based on a fixed set of chemicals to assist in risk estimations, Probability of Ignition of a Released Flammable Mass converts a "best guess" to a calculated value based on available information and current technology. The text documents and explains the science and background of the technology-based approach. The tool, when populated with appropriate data, yields an estimate of the probability that a defined release of a flammable material will ignite if exposed to an ignition source. This information can be used to make risk assessments with a higher degree of confidence than estimates made before and it provides valuable information for use in the development of a facility's Emergency Response Plan
  Guidelines for Fire Protection in Chemical, Petrochemical, and Hydrocarbon Processing masoomi 0 3,334 07-06-2020، 06:13 PM
  Guidelines for Investigating Process Safety Incidents masoomi 0 2,724 05-11-2020، 12:38 PM
