دانلود نرم افزار ارزیابی بلند کردن بار به روش mac
دانلود نرم افزار ارزیابی بلند کردن بار به روش MAC
نام نرم افزار: نرم افزار ارزیابی بلند کردن بار به روش MAC
.xlsm   MAC.xlsm (اندازه 286.4 KB / تعداد دانلود: 62)
[عکس: mac.JPG]
[عکس: mac2.JPG]
Values in the summary table and what they mean
Individual weights
The number of lifts performed in 1 kg steps
The maximum load
The colour band of this load tells you how severe the heaviest lifting task is
The 25th percentile load
The 25th and 75th percentile loads tell you something about how spread out are the loads that are being handled. Half of the loads are between these two values. As the loads get more variable, the difference between them gets bigger The 25th percentile load tells you something about the lighter loads that are being handled. A quarter of loads weigh less than this, and three-quarters weigh more so it is mid-way between the lightest weight and the median. It’s the middle point of the light half of the job
(The average load (mean load
This is total weight handled divided by the total number of lifts. This is what the worker would handle if all the loads weighed the same. The colour band tells you the level of risk of the overall demands of the task
(The middle load (median load
If you arrange all the weights in sequence this is the middle value. It splits the weights into a heavy half and a light half. Like the mean, the colour band of the median tells you the level of risk of the overall task
(The most common load (the mode
This is the weight that is handled most often. If this is heavier than the mean or the median then check if you can reduce the number of times that items of this weight are handled. Its colour band tells you the level of risk of handling the most common weight
The 75th percentile load
The 75th and 25th percentile loads tell you something about how spread out are the loads that are being handled. Half of the loads are between these two values. As the loads get more variable, the difference between them gets bigger. The 75th percentile load tells you something about the heavier loads that are being handled. Three-quarters of loads weigh less than this, and one quarter weigh more so it is mid-way between the median and the maximum weight. It’s the middle point of the heavy half of the job
The carry factor
This takes account of the amount of effort and time spent in carrying loads. It converts the total distance carried into an equivalent number of lifts and adds them to the bar for the mean value. If you don’t enter any carry distances then the height of this bar is the same as the mean bar and it will be hidden behind it
Overall colour band/score for MAC score sheet
This colour band and score are what should be entered into the ‘Load weight and lift/carry frequency’ line of the MAC score sheet PDF
Total load handled
This is the total of the weights of all the individual lifts
The total number of carries
This is the total number of carries of more than 2 m distance
The carry distance
This is the total distance involving carries of more than 2 m distance
.pdf   MAC score sheet.pdf (اندازه 5.21 MB / تعداد دانلود: 12)
  دانلود نرم افزار ارزیابی پوسچر REBA دانشگاه کورنل masoomi 2 8,100 01-27-2026، 09:54 AM
آخرین ارسال: elahemohammadhashemi
  دانلود برنامه اندروید روش ارزیابی پوسچر REBA masoomi 2 6,357 11-29-2024، 08:18 PM
