سوال 29 کنکور ارشد مهندسی بهداشت حرفه ای سال 97
29- به طور معمول، محاسبه TLV با استفاده از کدام یک از پارامترهای زیر انجام می شود?
الف) Reference dose
ب) Safe Human Dose
ج) NOAEL
د) LOAEL
 The Safe Human Dose
 The calculation of a safe human dose essentially makes an extrapolation on the basis of the size differential between humans and the test species. Usually this is a straightforward body-weight extrapolation, but a surface area scalar for dose could also be used. The calculation is similar to the following
[عکس: 972929.JPG]
NOAEL = threshold dose or some other no-observable-adverse-effect-level selected from the no-effect region of the dose–response curve
SHD = safe human dose
UF = the total uncertainty factor, which depends on the nature and reliability of the animal data used for the extrapolation
 N = number of milligrams consumed per day
[عکس: 97292929.JPG]
Two methods of estimating the threshold are used. The more desirable method uses the highest reported dose or exposure level for which no toxicity was observed. adverse effect level” (NOAEL), is considered for practical purposes to represent the threshold dose. Sometimes, the available data do not include a NOAEL; that is, all of the doses tested produced some measurable toxic effect. In this situation, the lowest dose producing an adverse effect,  termed the “lowest observable adverse effect level” (LOAEL), is identified from the dose response data. The threshold dose will lie below, and hopefully near, this dose. A threshold dose is then projected from the LOAEL, usually by dividing the LOAEL by a factor of 10 (see Figure 18.3
the greater the uncertainty that the NOAEL or LOAEL from the literature actually represents the threshold dose in humans
The purpose of dividing the NOAEL or LOAEL by uncertainty factors is to ensure that the SHD used in the risk assessment is below the actual human threshold dose for toxicity for all individuals in the exposed population, thereby avoiding any underestimation of risk. The greater the uncertainty associated with the data, ظthe larger the uncertainty factor required to insure protection.The general rationale for selecting the size of the uncertainty factor for a particul ararea of uncertainty is as follows
بررسی و تحلیل توسط دبیر انحمن در انجمن بهداشت حرفه ای ایران
  سوال 23 کنکور ارشد مهندسی بهداشت حرفه ای سال 97 masoomi 0 2,078 07-26-2018، 10:23 PM
  سوال 22 کنکور ارشد مهندسی بهداشت حرفه ای سال 97 masoomi 0 2,230 07-26-2018، 10:15 PM
