Isopropanol, Anhydrous
by Dow
Causes serious eye irritation
Highly flammable liquid and vapour
May cause drowsiness or dizziness
Precautions
Keep away from heat, hot surfaces, sparks, open flames and other ignition sources. No smoking.
Keep container tightly closed
Ground and bond container and receiving equipment
Use explosion-proof electrical/ventilating/lighting/.../equipment
Use only non-sparking tools
Take action to prevent static discharges
Avoid breathing dust/fume/gas/mist/vapours/spray
Wash ... thoroughly after handling
Use only outdoors or in a well-ventilated area
Wear protective gloves/protective clothing/eye protection/face protection
IF ON SKIN (or hair): Take off immediately all contaminated clothing, Rinse skin with water/shower
IF INHALED: Remove victim to fresh air and keep at rest in a position comfortable for breathing
IF IN EYES: Rinse cautiously with water for several minutes, Remove contact lenses, if present and easy to do. Continue rinsing
Call a POISON CENTER or doctor/physician if you feel unwell
If eye irritation persists: Get medical advice/attention
In case of fire: Use ... for extinction
Store in a well-ventilated place., Keep container tightly closed
Store in a well-ventilated place., Keep cool
Store locked up
Dispose of contents/container to ...
Hazard category
Eye damage/ irritation, Flammable liquids, Specific target organ toxicity, single exposure; Narcotic effects
Danger
Hazard statementsCauses serious eye irritation
Precautions
Store locked up
Hazard category
![Adobe Acrobat PDF .pdf](https://www.occupationalhealth.ir/images/attachtypes/pdf.gif)
