biomechanical risk assessment during field loading of hydraulic stretchers into ambulances
Biomechanical risk assessment during field loading of hydraulic stretchers into ambulances
Jer^ome Prairie a, *, Andre Plamondon b, Sandrine Hegg-Deloye a, Dominique Larouche a Philippe Corbeil a
a Groupe de recherche en analyse du mouvement et ergonomie, Universite Laval, Departement de kinesiologie, 2300 rue de la Terrasse, Quebec, QC, G1V
0A6, Canada
b Institut de recherche Robert Sauve en sante et en securite du travail (IRSST), 505 Boul. De Maisonneuve Ouest, Montreal, QC, H3A 3C2, Canada
c Centre de recherche du Centre hospitalier affilie universitaire de Quebec, Quebec, Canada
Abstract
The process of loading a stretcher into an ambulance is known to cause a high incidence of back injuries among paramedics. This study aimed to assess the forces at L5/S1 during real-life stretcher loading activities and to determine the variables that contribute significantly to these forces. Analyses involved 58 paramedics (111 shifts) and 175 stretcher loading activities. Estimates of compression and shear forces at L5/S1 were calculated using the 3DSSPP program. Seventy-one percent of loading activities exceeded the safe loading level of 3.4 kN compression force at L5/S1 (mean: 3.9 kN, min–max: 2.1–7.0 kN). About 92% of the variance can be predicted from a combination of several variables, notably hand load (mean: 0.72 kN/number of paramedics) and back sagittal flexion (mean: 32°). Recommendations to reduce the risk of back injuries are proposed with regard to stretcher and ambulance loading design as well as training in stretcher lifting for paramedics
Relevance to the industry
The results of this study suggest that ambulance stretcher manufacturers should make ergonomic design changes to reduce the physical strain on paramedics’ backs during the process of loading a stretcher into an ambulance. Other preventive measures (e.g., training) must be formulated and applied to reduce the risk of back musculoskeletal disorders during the loading of stretcher patients. For instance, training should focus on back posture, teamwork and equipment/patient positioning on stretchers
.pdf   Biomechanical risk assessment during field loading of hydraulic stretchers into ambulances.pdf (اندازه 1.34 MB / تعداد دانلود: 1,361)
  Correlation among cap design, gripping technique and age in the opening of squeeze-and-turn packages: A biomechanical masoomi 0 4,716 07-29-2016، 12:40 PM
  Analysis of the mental workload of city traffic control operators while monitoring traffic density: A field study masoomi 0 3,977 07-29-2016، 12:35 PM
